Te Koop Robland X-31 combinatie machine
medvadze
8 sep 2022
14
For sale: grey Robland X-31 5-in-1 combination machine. Well-maintained and in good condition.
Equipped with a Shark Guard dust extraction system with a 100 mm throughput and matching blade.
Asking price € 2,800.00, to be picked up in Garmerwolde (Groningen).
I've bought this machine from the fellow forum member this is the link to the original post: ORIGINAL POST
I've been using this machine not that much but always enjoyed it.
Let me copy specs in dutch from the original post:
  • 380 volt three-phase power
  • on wheels with a handle to move the machine
  • complete with many accessories [see photos]
  • freesas 30 mm
  • flat-thickness bench, 310 mm wide, 230 mm high
  • detachable long-hole drilling rig [incl. drills]
  • 100 mm extraction at the bottom of the machine - saw table
  • The bearings on the saw shaft have recently been replaced.
  • Table saw cuts from 90 - 45 degrees
  • incl. saw blades 250/30 mm for ripping [24T] and crosscutting [48T]
  • A very powerful machine with 3 x 4 hp motors
  • The machine is otherwise original.
Changes since 3 years ago:
  • New planer/thicknesser blades - I've installed 3x new blades with tungsten carbide edges (not spiral head)
  • Installed 3d-printed dust extraction connectors with magnetic fixation - can be attached/detached in seconds.
Viewing or/and buying is possible after Aug 15th when I'm back home from vacation.
I have no facility to load it to the truck or trailer unfortunately.
A few fotos below (also, please have a look at the photos in the original post by Jan)
