Felder KAPPA 40 x motion
A.N
12 aug 2010
250
36
Schoonoord
Functions are used for repeatable sawing techniques, grooves in drawer boxes for example.
Don`t you have a manual? If not, I have it in Dutch, maybe in English, will have to look tomorrow.
I don`t use all the Functions, only 3
trilliwilli
1.061
11
Leiderdorp
I find it hard to believe that you don't have support with such an expensive and exclusive machine. Manuals are available in all languages for these machines, you should contact the supplier, they can help you. Didn't you get an explenation when the machine was installed? It's common on these premium class machines.
A.N
12 aug 2010
250
36
Schoonoord
De Format 40 x-motion is het oudere model, werd volgens mij tot 2010 of 2011 gemaakt. Ze worden wel eens bij veilingen en machinehandelaren aangeboden, dan ontbreken vaak de instructieboekjes.
I will look for the English manual, I`m not sure if i have one.
justarby
2 nov 2015
33
Hello
I took it second hand but in a very good condition.
I. Holland they dont have english version and that was the amswer.
They will look about vorritser how to solve my problem.
Thanks
justarby
2 nov 2015
33
I have found the problem,
zaagblad what I use is 250 mm and mamchine was set up for 300 mm.
It works good ,Thanks
