Where can I buy lijnzaad?
Geppetto
18 mrt 2014
34
Hello guys,
I am making a cutting board, where can I buy some food safe lijnzaad (I think this is the correct translation in dutch),
to protect the board?
Many Thanks
Nic
Aeolos
27 nov 2014
327
81
Hey Geppetto,
For finishing cutting boards, there's a variety of ways. I'm not sure linseed oil is the way to go here - most of the standard stuff is full of desiccants to help cure the oil, and I wouldn't put that on food stuff. There is the "traditional" BLO from the Cokerije (http://www.hout-olie.nl/), but I'm not sure if I'd do that either. Over here, most people seem to finish their cutting boards with a natural oil like grapeseed oil, which is quite foodsafe.
I'm sure many more forummembers with more expertise can comment further on this.
O Peatey
29 mrt 2010
2.340
187
Enkhuizen
I use always the paraffine oil from IKEA. They sell it especially for cutting boards under the name of SKYD. It is quite cheap.
Aeolos
27 nov 2014
327
81
That would work just fine for most people, but it's often avoided because of nut allergies. Apparently even the slightest hint of a nut can be enough to send someone into an anaphylactic shock.
Geppetto
18 mrt 2014
34
Thanks to everyone, since I work right in front of IKEA, I will stop on my way out and get this SKYD product,
but I also heard really good things about Tung oil, so when I get a chance I will order one from De Cokerije.
Thanks again for all your help and suggestions.
Nic
3.713
1.310
The kind of oil you use is not that important (it should be edible), the most important thing is to oil your board regularly, eg at least once a month. Oiling is what keeps it clean (capillary action of the wood fibers).
