Wegens stoppen met hobby te koop
The No. 7, the longest of the Rider planes levels the bumps and hollows to leave a true edge prior to jointing. All Rider planes are good quality and suitable for home or professional site or bench use. The No. 7 is useful for the final flattening of a surface before using a smoothing plane.Well made, the Rider version has many excellent features. The main casting is ductile iron chosen for its high strength and impact resistance. It has an adjustable frog, depth and lateral blade control and Indian rosewood handles. The cap iron and other quality fittings on the planes are solid brass, an ideal material for moving parts.
The sole is 560mm (22") long with a 60mm (2-3/8") wide blade. The sole of the plane is flat and accurate to +/- 0.04mm (0.0016"). At 4.2kg (9-1/2lb) it slices through knots and difficult grain.
Rider planes only require the bare minimum of initial preparation. The blade comes honed with a secondary bevel ready to take shavings. Each blade is oil quenched, high carbon spring steel, hardened and tempered to HRC 63.
Nieuwprijs €160
Nu te koop voor €75
Op te halen in Delft of versturen per post +€5,95 verzendkosten
Kijk ook bij mijn andere advertenties
