Sorry, Ik had deze en dacht dat het M2 was.
The CL1 is a heavy weight cast iron lathe with solid chromed bed bars; in fact these are the same bed bars which are fitted to the professional standard CL3 and CL4 lathes. Also shared with these larger lathes is the No. 1 MT tailstock, a beefy item which carries plenty of weight to dampen vibration when spindle turning. The headstock is cast grey iron and fitted with sealed for life maintenance free bearings ensuring smooth running and offering generous capacities, up to 15" if the headstock is swiveled. This lathe is perfect for the serious wood turner who requires a versatile yet reasonably priced lathe.
