Als eerste mijn excuse voor deze thread - aangezien het in het engels is.
Zoals jullie weten (of niet) ben ik in Engeland woonachtig en ben regelmatig op de engelstalige houtbwerkings forum- daar heb ik vandaag deze bijdrage geplaatst. hier van nu een afschrift. helaas in het engels, maar met genoeg foto's om het geheel duidelijk te maken. Ben altijd bereid om vragen te beantwoorden - in het nederlands
Secret Book Shelf Door
My wife bought about 2 years ago these double secret bookshelf doors. They were originally to be fitted as access doors to our library. We later decided against this, due to the fact we wanted more light into our hallway and changed the design that all the doors leading off the hall ways are to be double doors with glass panels, which meant we weren’t going to use these doors in their intended place
The doors in question
Doors1 by mcluma, on Flickr
Doors3 by mcluma, on Flickr
Doors4 by mcluma, on Flickr
And the other side of the doors
Doors2 by mcluma, on Flickr
As we got underway with the refurbishment of our house we midway changed the ground floor layout. Originally we planned a double internal garage with at the back of the garage the plant room and Gym. Walls and doorways got build, and as these are structural walls they couldn’t be moved without a cost aspect. In the new lay-out the garage is to become our new lounge.
So a solution had to be found for this doorway into the Gym
Untitled by mcluma, on Flickr
Which we had and that are the secret bookshelf doors!
So after the floor was screeded the walls plaster boarded and plastered I set about to fit these doors.
Originally they were fitted with 3 hinges each. Now there was no way I was going to use these hinges.
1) The door weighs a hefty 100kg (or so I think, as it was more then I could lift) so this was not going to work with just 3 hinges (no ball bearings)
2) The door is to open outward, so the hinges had to be changed and would then be seen from the inside
I found the solution in using these Hafele floor hinges
http://www.hafele.co.uk/Hafele35a1/Images/400_300/932.10.760P1.JPEG
These are rated up to 150Kg
Here the doors in position to show what it’s going to look like
